Well, now that the weather is getting warm again, I think I need to ask this question: At what point should I worry about engine temps? On the highway, I'm always below 180, and usually closer to 160, but in city traffic I've been concerned a few times. The worst I ever had was about 230* on a 95+* day stuck in DC traffic. As soon as I saw it I shut her down and pulled over for a while. Once I got on the highway, I was running around 175* and when I checked the coolant later it was almost full still.
More commonly, there have been a number of times on warm days when I look over and see something in the 200-210 area, at which point I get nervous, but if I am able to get moving, it drops down pretty quick. Every time I check coolant levels, they're fine. I don't think I've ever needed to put more than maybe a quart in, and that was after an extended period of not having been checked.
As to the cooling system, there is a single electric fan attached to the radiator, which is an aluminum F-body radiator. Or at least the piece of paper I got from the previous owner said that's what was in there... It's only been around 1000 miles since being flushed, but time-wise, it's been a while, so maybe I should do that. Does that water wetter stuff actually work?
Anyway, I would appreciate anything anyone would be able to tell me about this, like, should I be more concerned, or...?
Thanks,
Brad
Thanks,
Brad
