How low can I go?
Turbojorge
Unstoppable
I Did a couple changes to the car over the weekend and now I can't seem to get my BLM's above 105 at idle. Even If I turn to FP at 40psi line off, the BLM's at Idle are bellow 110. The biggest change That I did over the weekend (IMO) was that I put One of the screens back on the MAF. The Iac counts are good (20 or so) at Idle and the TPS is set at .42 (4.68@WOT). Right now, the FP is set at 42 Line off. The O2's are good at 790 at WOT in 3rd but I have a bad tip in stumble in idle that is killing me. I mean I have way big injectors (009's) for my Turbo, so I'm wondering If my FP at Idle is too much. If So, what would be the lowest I could go and still be able to run 17psi (as I can do now) on 93 octane with no KR.
I want to get rid of the Freaken Tip in Stumble. :mad:
TIA
Whose chip are you running? Let me guess---Reds? All my Reds chips were pig rich on idle. It drove me nuts. Actually it drove me to buy the ME. My BLMs were 105 at best and most of the time bottomed out at 90.
Yup, It's Reds 93 chip.
"My BLMs were 105 at best and most of the time bottomed out at 90."
Same here.
"Actually it drove me to buy the ME."
I want to get this Tunning stuff :D down pack with what I have now on pump gas before I take my next step. The less buttons to push and the less setting to adjust Right now the easier it is. I don't want to adjust 47 different things at once, because chances are I won't find the real problems. I want to get the car to run right with what I have and then move on to the next step.
I don't want to buy an Alcy kit and a Turbo link for my car and still not even have an adj. waste gate. :D ;) :o :o :o
"I don't want to buy an Alcy kit and a Turbo link for my car and still not even have an adj. waste gate." - Yeah, you'd have to be a dork to do something like that! ;)
I'd talk to red and tell him what is happening. Yes the ME is very complex, but its pretty much on the money right out of the box.
