Hello,
I live in California but will be relocating to Ireland in the fall to pursue my graduate degree and want to sell my GN. It's a 1986 T-Top GN with 109,000 miles. The only mods are as follows:
17'' Torque Thrust II's
42 lb/hr injectors (b/c two originals went bad)
Ta-60 turbo (Still have original turbo but needs to be restored, blades are all cut up)
Scanmaster
Custom 91 Octane Chip for smoother idle, etc etc. stock boost levels.
Other than that, she's bone stock, except for a fully restored suspension which I did last summer. I'm talking new body mounts all the way around, new shocks, springs, tie rods, etc. I also have the oringinal GN rims on hand in my garage and the original steering wheel. The car's interior is about the best it can be for being so old, and the exterior is nearly flawless with an expensive paint job about 5 years ago. The only flaws on the exterior are a ding in the rear drivers side panel and a couple knicks along the bottom of the doors from rocks flying up during driving. Other than that, you can shave your beard because it's so shiny.
When I originally bought the car it ran horribly but I have fixed it up to where it passes CA smog tests legally, has about 25 psi of oil pressure at idle, brand new timing chain, and almost perfect scanmaster readings. My original intention was to modify and race this car and perhaps do a 4.1 swap but I never got around to it since I was away at college the entire time. Therefore, it literally just sits in the garage and I bought the car with 107,000 miles on it and it only has 109,000 on it today after 5 years of ownership. I've only taken it to the drag strip in stock form one time when I first got the car and ran a 14.0 at 98 mph on stock boost. It's never been beaten on and has always been dearly cared for. I will post pictures later but what do you think I could list it for?
Thank you very much.
Scanmaster
