How quick should my combo go
spool it up
Hey guys
This what car has done on 104 and 20lbs. of boost.
60ft 1.79
1/4 12.471
speed 108.48
I think it should be 12.0 to 12.20
I leave on 4lbs of boost and only want to run 20lbs of boost.
See sig for combo.
Thanks guys
Rick
Originally posted by spool it up
Hey guys
60ft 1.79
1/4 12.471
speed 108.48
See sig for combo.
Thanks guys
Rick
Your 51 is not in its sweet spot at 20 psi. You might as well run the stock turbo if you are going to limit yourself to 20. Turn it up to 22-23 psi and/or launch with more boost and see what kind of a difference it makes. I bet you would end up around 11.7's or better.
Thanks c&cgn
I did order a new converter with a 3000 stall so I could leave with more boost. I will also turd it upto 22lbs.
Rick
With your parts, I wouldn't be happy until I was running 11.30's anything less than 11.8's is the waste of a FMIC and 009's. Slower than 12.0, no need for a PTE51, a stock turbo will do that.
24 PSI of boost, 114 min octane, race chip using a 28" tall tire.
friends car with stock motor stock i/c and 009's with a te51 went 11:59 at 116 on 110 chip and 26 # with 1.6 60 fts car weighed 3720# race weight.
no need to say nothing about why its not still doing it..
he's going to a different turbo now :confused:
I know I can go faster on 110 and 110chip and more boost, but I'm trying to see how far 104 and 104 chip will go. All I run for gas is 104 sunoco. This way being unleaded gas I save on O2 sensors. Thanks for the info.
Rick
Hey spool it up,
Remember me from Great Lakes. (The kid with the GN). Its not every day you get to line up next to another TR. (By the way thanks for making me look slow.);) :p After seeing your car I just cant wait to get mine tuned, put some more goodies on there, and let her rip. Right now I cant hold any boost, I have no traction, and I'm getting knock at 15lbs:eek:. (Those first two made for some ugly 60ft. times:mad:). Hopefully next time will be better. Slow and steady, steady and slow thats the way I always go. (Of course, except when I'm in the GN:D ). Anyways nice car.
Carlos
Rick
With ported heads, a front mount intercooler and a TE 51 you still should run 11.8's @ 113 with 104 octane.
12.4's @ 108 can be done with a stock longblock, stock turbo/intercooler using 104 and a 100 chip at 19 psi of boost.
There is a lot more in your combination than you are seeing.
I can run about 8 mph faster than you with less of a combo. I am using 93 octane + alcohol. You have a lot more potential in your combo.
