How to cure 2-3 bind
85 Riviera
If a trans was to bind on the 2-3 shift would it be more likely to do it on WOT than on part throttle? How do you cure a slight bind, would a stiffer servo return spring help or is there a better idea? I felt a bind from 2-3 on full throttle but it was only twice on the same day and went away on the next drive so I want to know how to cure it just incase it comes back I can battle it!!! Thanx!!!
Stiffer spring might help, but will also cause more resistance for 2nd to over come.
