try adjusting the window pin that interlocks with the nylon loop thats on the rear of the glass (inside the door) ..move it outward
you need to remove the upper door panel to get at it
you can also adjust the rear vertical track at the top of the door , move it outward toward glass to push glass against dew strips which makes the glass move toward weatherstrips
also make sure your dew strips arent worn out
