hv oil pump or not
v6shooter
In the middle rebuild would like some advice on this subject. Not sure what to do:confused:
Call Dan @ DSL and have him put a cover together for you. You will not have to worry about it any more.
Take your stock cover & if its in spec then do the Earl Brown treatment to it & it will be Perfect! No HV needed. Plus they put added wear on the cam & cam sensor. See Vortex Turbo Buick Performance for the cover specs
search Earl Brown for the writeup or their is a sticky in tech articles on turbobuicks
