Hydroboost master cylinder
MIB
Are there any problems with using the stock astro mc? If so are there any others that will bolt up? I know there are several different ones from the astro van. I see some with 2/4-wheel ABS. I have the hoses fabbed. Thanks
I wouldnt think so. I used everything from a 95 Astro Van and it works great. There was no electronic hookup (ABS) and I am using the stock (GN)proportioning valve and no problems.
Sounds good :D. My set-up is from a 93 astro. I am going to finish up the bracket tomorrow and start hooking everything up. Thanks
when i had my hydro i got a replacement master cylinder from a 85 diesel caprice wagon, at lee auto parts.
I searched around. I looked at the C3 corvettes and wilwood. The corvette mc is cheap and you can get it everything from billet to cast iron. I think I am going to keep it simple and stick w/stock mc :D. Thanks
