turbotaone
- Jan 22, 2003
I'm not sure how it happened exactly, I was racing a Ford Lightning(I beat him the first run)and all of a sudden "POW"
it sounded like a large firecracker going off under my hood and
then pop,pop,pop,pop sounds like a bad exaust leak coming
from no.1 cylinder. So I pulled over and opened the hood and
there wasn't any fluid leakage and the temp. and oil pressure
were ok so I started to drive it home with the Lightning following
me. I made it about a mile and the temp. started going up so I
pulled over and let it cool down and then added some water, it
didn't even take a half gallon to top it off. I started it up and
drove the rest of the way home and the temp. never went over
160*. I was running 20lbs.of boost with a zylene mix all summer
with 0 knock and I had the same set up last night when this
happened. Only thing I can figure is with the cooler temperature
last night(40*) I should of raised my fuel pressure, which I didn't
and it went lean. Anyhow I need some advise on which head
gasket to use(stock or the metal shim type)and should I take the
head to a machine shop and have it checked for warpage? Are
there any things that I should watch out for when changing the
headgasket? Did I do more damage by driving it home?,it was
late at night and I was only 15 miles from home, so I thought
what the hell. Any helpful advise will be appreciated.
James
Hey Razor, I sure wished that I had that alky kit last night
James
