iac prob
krom415
scanmaster reading 00 iac at idle all other #'s good tried to set iac got it to 7 but at like 2500 rpm any advice ...tia
Try the IAC reset procedure, then adjust the throttle plate to get a reading between 9 and 19 and always recheck your TPS. Should be .42/.44.
if you have scantool or scanmaster you dont need to do the iac reset, just keep adjusting the butterfly, and make sure you stay within range on your tps .42-.44 clockwise on the scew lowers iac, counterclockwise raises the setting, after you make an adjustment drive around the block or down the street and recheck it. It might take a few adustments to get were you want it.
