IAC setting
nicey623
How fast.... V6 fast
need some help. what should my IAC read on my scanmaster when the car is up to temp.
Also where can I get a hollow front sway bar?
I'd shoot for IAC somewhere between 10 and 20, but it doesn't need to be exact. Mine generally hovered around high 30's before I cleaned the throttle body last week, now it's usually below 10. The higher the number, the more the computer is calling for air to keep the idle up. If it's 0, then the idle is not under control by the ECM (air bypass closed) and it may idle higher than 750. Remember, car warm, in park, and no accessories on.
:cool: thanks, it seems like it idles rough but I think I have a vacuum leak
If you have a vacuum leak then your BLM's wont be at 125-131 where they should be.
Click the SM button till ya see BL.. at idle..accessories off.. ;)
If its leaking they'll be 140+
HTH
BL above 140, mechanic sprayed cleaner around my intake & it reved up real quick so that is probably the problem. Fixing stuff this winter for next year, going with a gasket from Jegs
