N
NSXPOWR
Guest
I have an 87' GN that used to idle up and down when cold and when you put it in gear it would die. I adjusted the throttle stop screw and the tps sensor. Now it idles pretty well until it is put in gear. It still dies until it warms up. I noticed that when I scan the sensors the park-neutral switch, it never shows it's in park, but it does show when in neutral. Car will start in any gear. Will this switch cause this kind of idle problem? Like I said the idle is now fine until I put it in gear, and then it will die until it warms up.
Thanks John T.
Thanks John T.
