If I install flares (GNX) will I still need wheelwell moldings?
Boston GN
How do these things install and will I need the wheel well moldings anymore. Reason I ask is the car is in for restoration after an accident. Figured I'd do it all while it was in. Now, I can get used flares for under 200 where as finding good wheel well trim is very difficult and some people are asking rediculous money for them.
I'm guessing I would probably need a different set of wheels to ( I have stock) because I'm sure the car would look silly with those tiny wheels stuck half way in the fender well.
no trim under the flares uses the same holes the fender trim uses to hold it on
Even if you install the GNX fender flares, won't you still have to roll the fender lip?:confused: I mean you can't just install larger tires b/c you put on fender flares right?
