IGN 1 terminals?
87GNcospg
Send your Donations
some how my ign 1 terminals no longer supply any power. i am referring to all 3 of the IGN 1 terminals on the left side of the fuse box. i noticed that my alky kit wasnt getting any power yesterday. i tried all 3 terminals and none of them worked so i put the alky in to the ign 3 (with my gauges) terminal and it works.
i am not sure why those 3 terminals no longer work. is there a fuse somewhere for them?
I don't have a wiring diagram in front of me to verify this, but the first thing I would look into is the fusible links at the starter. I think there's 3 heavy gauge red wires, each with its own fusible link. Good Luck.
if the fusible links at my starter were fried wouldnt my car not start?
Originally posted by salvageV6
20 Ampere STBLT/ACC Fuse.
Rear defogger and the chime module. :)
what are you referring too? what about the rear defogger and chime module? :confused: . sorry that i am so lost.
by the way, the chime module is the thing above the right bolt that holds up the under dash panel right? mine goes off randomly especially over bumps or if i barely touch it.
