Can anyone tell me where the ignition terminal on the fuse box is powered from? I’ve seemed a lost power on the ignition terminal on the fuse box.. Thanks
theres a 20a seat belt acc fuse that feeds the three ign 1 ports
the ign switch is responsible for the ign powers to fuse block , if you have power at the bat port in your fuse block the fuse link works, if no power there the fuse link by starter is probably gone
