injector i.d.
bought some slightly used injectors and wondered what they are?They are tomco rotary disc with the #'s621020 and D1720AA. Also has the #2467 on the upper body. Also what is the biggest injector you can run with my stock computer , and will these work?
Not sure what those injectors are. Realize that you need a chip burned specifically for those injectors to run the car properly, or at all. Currently 50lbers are the max size avail prior to needing low impedence drivers installed in the ECM.
HTH
Jim
