Injector O-Rings
buddy
I bought a set of used 30# green top injectors awhile back. When I put them on I noticed a small fuel leak from #3. I just pulled off fuel rail and noticed that all O rings from injector to fuel rail are annialated.. Everything went on and off smooth and Ive done plenty of injector swaps. Not too sure why this could have gone so wrong. Anyway, does anybody know where to get a set of 12 Injector O rings for our cars? Thanks Rich
BK735-4584 is the Napa kit. its universal so there will be some extra rings in there. Any parts store should have them as stated above
Use some Silicone dielectric grease on the new o-rings when you install the injectors back into the rails and intake. In fact, one of those small packs they try to sell you with a set of plug wires should be plenty. Silicone dielectric grease won't disolve with fuel and will come back out with ease years down the road.
Thanks mike, I was planning on putting a small dab of spermacidal lube on the O rings.
It's ALIVEEEEE!!!!!!!!!!!!
Got the o rings. Used the lube. No leaks!!!Started right up for the first time in about 3 months. Couldn't be happier. Thanks for the suggestions!!!!
