Thanks Gary ...
The reason Dug posted this is because he was told by a few vendors that his injectors are not avail anymore. He could certainly purchase a complete new set of something else in a high ohm injector, but the ones he has now are almost brand new ... And money is a little tight at the moment.
The piston that broke in his motor really looked clean (lean) in comparison to the rest. I have a feeling the injector is not flowing as much as the rest, and just went too lean resulting in the fractured piston ... Since he just replaced the aluminum LS1 stock 5.7 block with a new 6.0 steel truck block and new low compression forged pistons, I just think he would be safe replacing that one suspect injector. Having it flowed on a bench would more than likely cost almost as much as purchasing a new one (if we can find a new replacement)
Anyway, he made 621rwhp / 684rwtq on a bone stock 10.1 CR motor with 12 psi of boost. and 91 octane pump gas.
Now, I just need to find where I can replace this so-called non-avail injector.
Thanks,
Ron (ex-89 TTA owner 11.87 @ 114)
