My build is almost complete and im looking for some advice on a fuel pump and pressure ratings. Still need the pump, pressure regulater, and blow thru carb. Any advice from you gurus is greatly appreciated. Stock 4.1 with 86-87 turbo setup
I am using a Mallory Digital 6 control for timing now but in the beginning I used only the 4 pin module and let the VR sensor do the retard control. It would work for boost up to high teens like that, with 19* initial ignition timing.
