Installing the RJC Valve???
ReaL99
I bought this valve about a year ago.the directions that came with it just don't match my wastegate.I don't have the stock type of wastegate or the THDP.I have a Racegate near the middle of the crosspipe and I suspect somewhere in there thats where this valve should go.Anybody have a Racegate with a RJC valve:confused:
Go here. SDinstructions They have great instructions with diagrams for most different setups. Don't worry about it not being RJC's site. These guys have been selling that exact controller allot longer than RJC and the instructions are accurate.
Thanks for the link but it does not show an illustration of a Racegate type Wastegate set up like mine.I printed the page out though.
Try running a hose from the compressor housing to the controller and from the controller to the racegate. The side of the controller with the hole should go towards the racegate. If the racegate has two ports you'll just want to run it to the one on top of the spring and leave the other vented to atmosphere. I think that's how it goes but my memory may be failing me. :eek:
Thanks for the info.When i got the RJC valve I just put it on near the turbo but I knew it wouldn't help.This Buick shop about 60 miles away should know where it goes I hope.One strange thing that happened is when I switched from the bigger 60-1 Turbo to the TE-44 I could no longer control boost from the knob in my car.Its no big deal since I only run 17-18 lbs of boost on the street.Maybe something with going with the smaller Turbo.Im not sure why I can't control boost from inside my car anymore.:rolleyes:
