Anyone know how to remove the i/p? have the speedo cable off and the center 3-wire connection held on with a teeny-tiny bolt removed, but I can't find where the wiring on the far right side connects! I have to remove the entire set-up to resolder/repair the circuit board/film on the back and can't do it in car. any help at all will be graely appreciated. I just put on my Nitto's and NEED to drive
The auxillary harness on the right side is connected by a plug that is buried back in behind the radio area. Just keep tugging on it and you'll see the plug eventually.
