Intake track & turbo spool
deezdad
Jackie's cashing in on your wretched disfigurement
Pretty sure a 3" lt1 maf & maf pipe would be sufficient size to support the air needs of a te44, & that a ls1 3.5" maf & pipe would be overkill but would the larger size let the turbo spool up any quicker? Thanks ..
I've been running a TA49 (same as TE44, but with different cover) with a 3" MAF pipe and LT1 MAF for ten years. Spools great. The screens have been removed from my MAF, which surely helps.
The 3.5" does offer faster spool...... BUT in the real world that faster spool doesn't necessarily mean more performance. If you're building from scratch, there's no reason not go to 3.5". The airfilter is the most expensive part. Might as well get one with a bigger mouth. If you're wanting to get a 3.5" for faster spool and expecting large results you'll probably be dissapointed unless you really need faster spoolup time.
That being said, my 3" MAF pipe has a cross section of 6.47 square inches. An LT1 MAF has an area of 4.3 square inches. (66.46% of a 3" MAF pipe)
a 3.5" MAF has a cross section of 5.275 square inches. Even though it's a "3.5"" unit, the actual flow area is only 81.%5 of a 3" MAF pipe.
Damn. Now I know where the extra spool comes from. I need to write those numbers down.
