Intercooler tubing
808 87 WE2
where can i get intercooler tubing?...i wana try get it here locally first, before i go to the mainaland
anyone tried some local hydraulic shops?
mahalo
jeff
Did you only needed a certain one? You can try Hydro Air
Originally posted by 808 87 WE2
turbov6,...need inlet and discharge hoses...
thanks
Jeff
I have a spare turbo to IC hose if you need.
Kilgo's sells hoses similar in size, though I haven't tried them. They also have the S.S. T-Bolt clamps in the Marine section. -Though they have been out of the 2-1/2 inch size for a while. :rolleyes:
I haven't checked recently though..... :)
I bought some exhaust marine hoses from Kilgo's last year, before they ran out. These hoses are really strong! I believe I have some extra hose if you need it, but I have to check. This 2.5" hose will fit the IC to up-pipe and up-pipe to TB connections.
Keith
Turbov6, How much you want for the turbo to intercooler hose?
Keith, ..if you come across those hoses, let me know...how much you want for them?...been busy working and havent found the time to check out kilgos....
anyone know the size of the hose from the turbo to the intercooler??
mahalo
Jeff
Jeff,
You can have it, but there is a slight tear (just on the surface) you should not have to worry about it leaking. Its one of those heavy duty IC hoses.
Mahalo turbov6
whats your schedule like?...im pretty flexible,
Jeff
P.S...you phone number would be the in "Hawaii owners sign in", right?
Laterz
Hey Jeff,
When I went to Kilgo's last year, the clerk told me that they weren't planning to replenish the grade and size of hose that you need. That's what the clerk told me then, but I don't know if it's true or not.
I have three separate pieces of hose. Two are about 3" in length, which is about the length that the stock hose is. Then I have a heavier grade of hose that's about 6" long.
It's been awhile, but I think the cost of this marine exhaust hose was about $9.50/ft. plus tax. You can have it all for $5. Let me know if you want it.
Keith:cool:
Mahalo turbov6
Jeff
Laterz
Yes! I live in Kapahulu so give me a buzz
turbov6 and go for 1,
ill try and call and see if we can meet this weekend, if not ill try during the weekday
mahalo
Jeff
