How does the shifter plate come off. Does it have tabs holding it in? I tried gently prying the plate up from the sides and front with a plastic pry bar with no luck. Felt like something was going to snap.
Pull out the ashtray and remove the 2 screws there then remove the 2 7mm screws on the shifter light cover. Reach under to remove the socket. Just be careful cause the plastic may be brittle from age.
