Interior Trim questions
RenleyRenfield
I have searched and there are lots of old old posts on replacing the headliner.
Some of them are just for t-tops.
I have a 87 hardtop, and i need to pull off the trim around the headliner.
The pieces that have me stuck are the ones over the doors. Trim that goes above the main door window part, interior grey plastic straight piece.
Do they just clip on?
These things are really stuck on here! I don't see any bolts... Most want to double check with you all before i start pulling down hard on them...
This is what you have behind the trim.
Pull down the trim piece by holding the back side of the trim (outside side) and pulling down on the inside (interior side) the trick is to find where the clip is attached.
Sorry for late response, but for all those who also going through this ^ this worked. We got the headliner out last weekend and are going to try and save the mostly ok original with a little backing help and new fabric.
I am thinking of doing black headliner fabric instead of the OEM grey....
