Got in my car and went down thew block. Under acceleration the car stumbled and acted like it wanted to cut off, I basically idled back home. Scan Master shows a code 33. MAF. Is there any way I can know for sure this is the problem. I tapped the MAF to see if the car would stumble it didnt? So is it the MAF? Will the Scan Master show other problem codes as well or just the MAF, like a code 21 or 22? Is there anythig else I can check. Im visiting home and have to leave sunday so i need help real bad, any advice would be helpful.
