as the part # implies that gforce is meant for a th350 transmission and humped for a dual exhaust not a turbobuick and thats the forum your posting on so dont see what good that xmember would do for you with a 2004r and single turbo regal exhaust, amazon list it at 239.00 maybe you could flip it if you could find a buyer
if you have a th350 and a dual exhaust than thats what you need
if you need for a 2004r turbo car stock xmenbers usually go for around 75 plus the ride.
if you want lighter for race (only 8lbs vs 14 stock) the iceman chromoly is around 175 ,gbodyparts.com carries it http://www.gbodyparts.com/product_i...=1152&osCsid=4fb462a760c5d4039de0b084f1aea2cf
my car has a 400 sbc and th350 but i plan on swapping the 200r4 back into it. also it has a dual exhaust on it but the exhaust is dented to clear the x-member. Is there a better way to get around this and i thought since the th350 and 200r4 are the same length that it would work but im assuming now that it wont....
well.. this is "general turbobuick tech" forum
and you didnt give any info as to your combo
the th350 and 2004r may be close on length so that you dont need a different driveshaft to go from a 2004r to a 350 but the other way may be too tight on driveshaft
th350 case is 27 5/8 (short tail) and 2004r is 28 1/4
but the mount points are way different
th350 trans mount is 22 1/4 from bellhousing
2004r is 27 15/16 from bellhousing
the iceman cross member from gbodyparts has about as much clearance as you can get and mount the 2004r
