It hasn't happened very often but a few times I have started the car (cold) and had an issue where the car starts at my elevated target warmup idle and will not come down as it is supposed to. I can try and manually change settings to bring the idle down and it just won't budge.
The only cure is to shut the car off and restart it, in which case it finds the correct idle and runs absolutely fine. What could be causing this?
