Hello all,
I've been an avid Fbody nut for a few years now, and have owned LT1 and LS1 powered cars. Always been in love with the Buick's, but I couldn't find one I could afford back then. Well I just sold my 98 Z28m6 and found a sweet original 87GN in KY. This thing was well taken care of, garaged, no rust, but it does still have the crappy original paint. A few questions..is has the 'Astroroof; where it retracts and also elevates upward. I've heard these are pretty rare and make the car worth a bit, especially since it has the original paint with no ruse anywhere. Has a GNX dash cluster also..looks pretty trick. The car has a few items that I don't know too much about. There is a remote knock detector inside the cabin, hooked up to I have no idea what, and some led's under the hood. With this thing on, it has never went off or made any noise at all, and I never heard any audible knock, the most I could get was 13psi boost. Car ran hard for a while until the inlet hose came loose from the turbo, (has a kenne Bell intake system) Replaced hose and tightened and now the SES light stays on, even though I unplugged the battery for over 3 hours hoping to reset the ECM. Never happend and then the car didn't seem to run as hard...next I noticed (probably from me driving it like I was used to driving my 6 speed Z28) that it had started to blow huge amounts of smoke out of the exhaust. Didn't do this when I bought it. Well we determined it was the turbo's fault when we pulled the intake system off and there was alot of shaft play on the compressor wheel.
Basiacally what I am asking is what all do I need to but to get this thing flying.
It already has an AFPR, which I don't have a guage so I don't know what to set it at. A complete fiberglass airdam attached under the front bumper with intakes for the intercooler and engine (It says Kenne Bell as well as the GNX dash that's in it) It also has airbags in the rear with one tube run out by the rear license plate. It has a cold thermostat, usually runs 150 or 160, and Kenne Bell plug wires. The trans, which has a cooler, may have been rebuilt because it shifts very positively and always barks 2ng gear.
I know that I will have to get:
Some big fuel pump (walbro 340?)
Injectors (009's or 50's)
Turbo (T60?62?)
Exhaust? Down pipe? (not even sure what that is)
Chip...ugh..there seems to be hundreds...
...basically.......HEEEEELLLPPP!!
Just need you guys to point me in the right direction. This car is pretty much a toy and I'd like it to run atleast mid 11's easily and reliably.
Turbo (T60?62?)
