JUST PUT ON 275 Drag raidals
slamming 6
Drag Master
Does this mess up the speedo because of the hight difference betwean the 245s and 275s,BTW they fit great on 8in rims W/4in rear spaceing
Depends on the complete size of the tire. 275/50/15's are just a tad shorter than the stock tire hiegth but not really enough to throw the speedo off hardly at all. Other sizes will be off a bit as a 275/60/15 I believe is almost a 28" tall tire.
HTH
Like BOOSt said it dosen't matter on the width of the tire but the height of the tire measure the tire from the top to bottom if it is 26" your fine but if it is 28" the speedo wont read correctly.
275x60 BFG's will cause about an 8% error....it'll read slower than you are actually going ie. 60 on speedo is really 65
Any guess on how far my speedo is off? I have tiny li'l 215/60/14s right now. I plan to upgrade soon.:)
Nearing I dont know how to post pic's I have a new scaner just have to learn how to use it.Krom thank you for the hookup good info thanks to all for your help.HAPPY HOLIDAYS,AL.
