My motor is out and I was cleaning up the engine bay and cross member. Someone said I should replace it with a new K member. Not knowing what that was, I checked out a few sites.
It appears there are 2 kinds: one that includes spring pads and motor mounts and another that doesn't. Here's where I could use some education...
What does the one without the pads and mounts do? I thought it would replace the whole cross member, but obviously not. Is it to stiffen and control the front end?
I also see control arms with shock pads, so if you get the one without the mounting pads, I assume you use these arms?
If you get hte k-member with the mounting pads, you use tubular arms without pads? It looks like they are made for coil-over springs, you it sounds like you need to buy a complete setup(?)
So basically, what's the different kind of setups you can use and the advantages/disadvantages? This really looks like something to do when the motor is out, so now would be the time.
Thanks in advance for any help!
