KB plenum + TB * Accufab * Fuel Rail
sackracing
Staff member
Kenne Bell 70mm throttle body, plenum and 1/2" spacer.
I milled a flat spot on the back of the plenum and drilled and tapped it for a boost gauge 1/8" hose fitting and a 1/4" push lock fitting for the map sensor. I can include a pair of stainless 1/4" socket head plugs.
I removed the hardware from the throttle body, that's the way they came new, it uses the hardware from a stock TB.
They both could use some polishing.
150 shipped.
New Accufab regulator, bought it and found it wouldn't fit my champion fuel rail.
75 shipped.
Stock fuel rail, powdered black. Still looks pretty good.
50 shipped
MSD Dis4, with coil sandwich plate. I don't have any paperwork anymore except the sheet with the rev limiter settings.
125 shipped
I prefer paypal, and please call dibs on the thread.
sackracing@gmail.com
Paypal addy is same as my email address
I got a PM on the TB and plenum 5 minutes before the above post, if it doesn't work out you're next.
Throttle body and plenum sold
Everything else still available, if you want the DIS, it's yours.
Regulator sold to first dibs.
The best way for this to go is to call dibs and pay right away, please.
I will ship the regulator and plenum no later than Wed.
Everything else still available.
