Kirban turbo gasket
turboadict
Anyone had any experience with the turbo to header gasket that kirban sells?
Says it has a metal insert.
I had a copper one but it blew out after a thousand miles or so. Looking for a good replacement.
Before you try all kinds of gaskets, maybe you should think of having the mating surfaces machined flat, and use new studs. I never use a gasket there, and rarely have any leaking problems. On occasion, i have used copper gaskets, which are necessary if there already was a gasket in place, and never had one blow out.
