I checked every thing now , my tps is .44 at idle and 4.66 at wot. I am getting 806 -820 on the o2's in 3rd gear. This is at 15psi and 41psi with the vac line off. Thing is that i cant get it over 3800 rpm with out knock, highest was 4100 rpm. It seems ok tell about 37-3800 rpm then i start getting bad knock , iam talking the knock gauge is in the red all the way. I cant get the turbo link to save so i cant check the knock or any thing. I was getting 17psi but now all i can get is 15 this might help to, no leaks that i can find , and i just fixed all exhaust leaks. I going to check my scan tool later again to make sure its not my open down pipe making false knock.
i thought i would b--- about some tuning
