took my car to work today and on the way home i was playing with the throttle trying to get the feel of my new tranny and when i was doing about 30-40mph and hit it, the boost would go to just a little abouve 10psi and my scanmaster readings were 839 O2's and 23.9 degrees of knock!!?? but it was hesitating and the boost guage was fluttering between 10 and 15psi the actuacter is set at 15psi what would cause it to do this. i dident have the scanmaster with the old tranny but it never acted like this. the only new mods in the past 6 months are 3' massair meter and translator, power plate and tranny nothing elese changed. any ideas?? TIA
i found a line off on the drivers side under the egr valve that corrected the boost fluttering i have a solid # now and had just a little bit over 1.6 with 820's for o2's but i see some other lines i need to fix. thankfully it was not something really big yet
