labor knock
poppy1440
Hello, Can someone please take a look at my file and tell me what you think.
I can hear the labor knock alot but scan master and power logger and knock guage are not showing any detination, so maybe their isn't any but I can hear it easily.
Also, what on the power logger screen shows any info on the methenal spray. I mean like how much it is spraying, when it spraying etc.
No way to monitor Alky with the powerlogger unless you add the optional pressure transducer.
BLM's are high
A/F are lean of the target
And that MAP trace is crazy
I'd say you are really knocking and something is wrong with the sensor.
I think I may be having some issues with my knock sensor.
I let the engine warm up and I put the scan master on the setting that displays knock and had a friend tab the engine by the knock sensor and on the kn0ck sensor and the scan master didn't register any knock.
The engine was installed around three years so I don't think it's over tightened, because it's registered knock b4.
Do ya'll think I am correct thinking it might be bad.
