Hey guys I got a problem. my car is running kinda weird, wanna know if you guys ever heard of this. Idles rough, but when driving its fine. TPS and maf are good. both changed, and even swapped others in to see if it would make a difference. Also changed the IAC. Made none. If I floor it from a dead stop, sometimes it stalls. And if it doens't stall, it will hesitate quite bad. There also seems to be more turbo lag then used to. If i try doing a burnout, the engine sits there, at about 1,000Rpms tires slowly spinning. Then after about 3 or 4 secs, it jumps up to 5000 rpm, and the tires are smoking. Why this lag? When run in backup spark and fuel mode, she run great. If i unplug the tps, or the maf and drive it, it seems to be fine. Cept it stalls with the maf unplugged which is understandable. Can anyone think of what might be causing this problem?
