87buickracer
- Dec 2, 2004
car has 50lb injectors /218cam/ported heads/smc kit/lubrent alky chip. runs lean on idle and stalls out in gear. I have to turn up idle screw to keep from stalling while in gear with foot on break.It will set a lean code if i leave in gear with foot on brake. If i put in park, there is no load on engine and no code will occur. I do not recall having this problem when i ran the 210/205 cam. I'm thinking it's the chip or cam,or do I need bigger injectors?
