Buicksforever
- Aug 13, 2003
1987 GN has been sitting for sometime. Engine does not run. I need to move it, but the drive train seems to be locked up. I jacked it up and the left rear wheel does not rotate. The right rear wheel does rotate. There is not a battery in car. The shifter goes through the gears and the linkage moves in relation to shifter going from park to reverse to neutral to drive. Could the parking pawl be the problem and if so could it be because the car has no electrical power?
