Well i got the car to run 24psi no knock at WOT with the SMC Alky kit and 91pump gas,SMC pump speed set at 9, and boost coming on at 12pounds, but my 02's are still in the 820range, I want lower 02's without having to increase boost, 24psi is plenty for the streets, Do I decrease the fuel pressure which is set right now at 31static with line on, Or do I decrease the alky pump speed? Ideas welcome.. i want my 02's in the 790 range..
thanks in advance.
thanks in advance.
