Mad_Trbo said:
Can anyone provide a rough esitmate of where the stock ignition system begings to fail from a boost perspective. On my DSM the stock ignitio began to fail around 20 lbs are the buicks good up to 27 - 30 with no worry of spark blow out?
Bottom line, understanding plugs will have to be gapped differently for this level of boost can the stock ignition system handle the job?
I've run an eDist, with CNP coils, and now 3-ACCEL 300's (each one firing, an oem DIS coil). Even in daily driver mode, they were better then the oem. But with guys running as fast as they do with the stock setup, it seems few folks bother with working on the ignition end of things. With the eDist I was able to cut the side electrodes completely off, and run ~20 PSI of boost without missing. The ACCEL being CDI, gives the car an almost instant start even in the dead of winter (thou I have the later Quick Start 3x19 triggering, and later module/ sensor).
The eDist gets expensive, since you can hardly find a used one, and at ~30 a coil that adds up. You can find take of coil set-ups on ebay from time to time for about $100.
I found the 3 ACCEl units for less then $200, and Jeg's stocks the MSD CD conversions for each of the coils, when I got mine. And by using 3 of them, it gives me the multistrike coil firing up to red line.
MSD is advertising a new CNP coil, that they say is CDI compatible. IMO, those with a CDI would have to be the ultimate ignition setup.
To actually answer your queston, I've run the stock setup at 28 PSI without a hiccup. In around town driving, the *Seat of the Pants* says the better ignitions make a difference. There, IMO, is a diference between more or less steady state WOT, and around town when you're in and out of the various modes like cruise, Power Enrichment, Accleration Enrichment, etc, etc..
