LJMS/BTR Stage 1 Turbo LS Cam 222/227 113+3 LS1/LS2/LS3-4.8/5.3/6.0 - $200
true85HA
LSX SWAP CAM
This was pulled from my 5.3 after one month for a different combo. This cam on a stock 5.3 bottom end made 660 to the wheel at 13lbs.
$200.00 OBOI
Turbo Stage I Cam 222/227 .602"/.598" 113+3
When the combination calls for something a little milder, the stage 1 is where to look. It will let a 4.8 turn 7k rpm with a 7675, and it works great in daily driver 6.0's with 68-72mm turbine wheel turbos that don’t see over 6200. A very well-mannered cam with a noticeable idle but nothing too crazy.
