SignUp Now!Anyone out there know how to get their fast xfi to lock up their convertor.
I had the same problem. You have to go into "View", then go down to "System Configuration" then go to "Sensor Calibration" next go to "Rate Sensor Calibration". There will be 3 boxes. put 1800 in the first box, 995 in the second, and 100 in the last box. This Calibration is almost dead nuts on my car. If it doesnt work for you play around with the box labled "MPH Calibration". Then you can set you TCC lockup parameters. I was told that you need a driveshaft sensor and the FAST stuff, but I used this instead and saved some money. BTW I have stock gears in the trans and rear, and 17" rims.
Thank you for the advice, I think I am going to get the fast VSS then go from there.
I believe the shorting the two pins together on the ALDL will still work even with the XFI installed.
