Locking trans dipstick
T- Type Tim
Vice Chairman
Found this nice one at summit for 40 bux . Just an FYI if anyone has been on the hunt for one like myself
Quick update
The overall length of the tube and dipstick is shorter than the stock setup. I did verify it's accuracy against stock.
Also , I had to break out the torch and modify a couple bends. Overall I like the way it looks
Pulling this back up for some more questions. Could the stock tube be used and just slip the locking dipstick into it and did you verify the amount sticking out of the tube was the same to the stock dipstick so the reading would be accurate?
i pull the locking dipsticks from the s10 blazers from the bone yard , they look just like the allstar
the marks arent correct but all you need to do is compare the marks to the stock and remark the locking by putting notches in the side
Cool. I like roaming the junk yard.
