Looking For A Good Turbo/inj Setup
mustanghunter7
I was just wondering if anybody knows of a good turbo and injector setup :confused: right know I have
-XP fuel pump and hot wire kit
-Hooker catback with cat delete
-Postons headers, down pipe, and crossover pipe
-adj fuel presser regulator
-adj waste gate
-RJC power plate
-30 lb injectors
-custom cold air intake
-heated o2 sensor
-tourque strap
-and going to put in a True Track posi with in a week
You need to post what your goals are but for an upgrade without changing the converter I would go with the ta49 or te 44 and 50 lb injectors.
Unless you are going to push past 23 psi the stock turbo and your injectors are hard to beat.
I would stay stock until the turbo went bad but I would get a large neck innercooler, ported elbow on the down pipe, and get alky and a chip burnt for alky.
If you do go with the new turbo check with Mike at fullthrottle.
