looking for stock intercooler bracket studs
the wrath
I am looking for both studs that go into the timing cover at the bottom. If you have anything please pm me.
The studs are just 5/16-18x2.00
If your talking about the 2 that hold the plastic piece fitted around the wire harness. Just pick up 2....5/16 set screws.
The studs are two different lengths. The one on the drivers side has the cam sensor and thicker intercooler bracket to contend with. I can't think of the total length off the top of my head, I forgot to go to bed last night :)
those arent just studs .... they are special studded bolts that are standard SAE thread into to the block but where the intercooler bracket slides they are metric M8x1.25 for
a standard SAE stud would work but it should be have a nut installed and tightened before the intercooler bracket is slid on to keep the ic away from the crank fan
Dont make it more difficult then it has to be. The 5/16 set screws, 2 inches long will more then do the job. They will screw into the block as far as you need. I just ordered every nut bolt and washer for my new engine in chrome and have mocked up every one of them on the motor. He will need 2 set screws, 5 nuts and 5 washers.
Screw in set screws, apply washer to each side. Apply nut to each side. Slide on wire harness, apply washer and nut to each side. Slide on intercooler bracket and use last washer and nut.
Finished!!! All that for about $1.50.
