TR Custom Parts
Mark Hueffman - Owner
- May 25, 2001
Well, looks like its time to figure out where I am getting debris in my oil filter from. Noticed some small stuff in the filter last year, believe it is aluminum, doesn't seem to stick to a magnet. Decided to hope for the best and new element, oil and ZDDP and changed again a few weeks ago. (only put about 750 miles on her last year) Debris again, changed again and now 3 weeks and 300 miles later pulled the filter and more debris.
Mobil 1 since 4700 miles. Have been using ZDDP for years. Running one of my turbo protectors and the filter has a synthetic element so at least the turbo is safe. Pull the cage apart and you can see what it is catching. Almost wished I didn't know! My GN has only 37,000 on it and motor has never been apart except for valve covers and dropped the oil pan when I got first got it to do a rear main seal. No valve springs, cam, rockers, timing chain, nothing! Just as Buick created it. Using all the stuff in my signature and alky for years always careful to watch for knock retard which is never an issue. Oil pressure is the same as always, 15-20 lbs hot idle and pressure jumps up as soon as you get on it.
No noises, not burning oil and running great. Oil sample has been sent out for analysis but obviously something is not right. Just what I wanted to do on a holiday weekend. Car is not babied and sees over 100 mph just about everytime it is out. Haven't been to a track since 2002. Maybe 100 passes down the track total in it's life.
