I may have found part of my problem. I was out trying to get my car running better on a country road. I was having luck at first and was up to 25#'s. As I drove the car more it started sputtering and popping real bad. I then started to build boost slowly and saw my boost and fuel rising together, but when I hit about 15#'s the boost kept going up but the fuel pressure started dropping. Now I'm confused, I was up to 25#'s with it running real good but it was slightly lean(720 o2's). I pulled over and added a few #'s of fuel pressure, drove down the road a bit and turned around. I then romped on it and was rich at first then the poping started. I then built the boost slowly and watched the fuel press and saw it climb and then drop.
My father has a N/A V8 chevy with dual carbs and a tunnel ram. He has had 3 diff fuel systems in the car and finally traced his loss of fuel press down to his regulator heating up. Could heat be messing me up? The more I drove the worse it got, and I assume the hotter the engine compartment got. Any one have any input on what may be causing my loss of F.P?
My fuel system consists of:
Msd 50's
walbro 340 (hot wired)
adj. reg with aftermarket top and stock bottom
stock style fuel filter thats 2 yrs old and has had about 500 miles on it.
I also run a Translator plus, 3.5" MAF, and a extender chip. I was seeing around 210 MAF's and since the extender chip cuts MAF's in half then I guess my MAF's where really 420.
Any one got any input for me??
TIA: Jason
Msd 50's
TIA: Jason
