Low Boost Help
Jeff Strube
I have 97 Regal GS it is only making 4 PSI with 3 inch Thrasher Pulley it was making 12 PSI with it Before. Not shure what to look at.
Check to make sure your boost bypass valve is not unplugged, or checked for frayed/broken wires. When that is unplugged, the PCM will only allow ~4 psi.
Belt slip shouldn't reduce boost that much, unless the belt was very loose. But that is a possibility.
I assume you have supporting mods for that small of a pulley?
belt slipping was kinda what i was thinking.....Bypass valve could be it though...totally forgot about that...but where are you getting you numbers for the 3.0 at 11 psi stock 3.8's are around 7.5 to 8 psi, and a 3.5 or 3.4 is around 11-12 ish
