hot79sport
- Aug 26, 2002
my problem is that my turbo 3.8 is only making 6# though it was previosly making 18 # via an adjustable regulator, so i dissconnected the regulator and changed all back to original, but still only 6#, the wastegate actuator arm moves and is not stuck, after taking the turbine housing apart to check the wastegate, it appeared there was buildup and as if the puck wasn't fully sealing the port, can this be the problem? does it make sense? while it was apart i wiggled the exhaust impeller and noticed a little slop, where can i locate any bearings and seals to replace this, any help would be greatly appreciated, this is my first post, though ive browsed the site before and and it rocks.
